I collected my neutral white TN12 from the post office. Somehow I don't feel excited about it at all and have been delaying my time to get to the post office until the evening prior to them closing for the day. Even after collection I didn't even bother to unwrap it for a full 5 hours when I had all the time to. Maybe I was jaded since I already have a Fenix PD35 TAC which I like very much, but then what's the difference in another new light with the same UI and output? Well, I took my time unwrapping the packaging, all these while feeling no sense of excitement whatsoever. Nothing. Zip. No feelings for it.
Then I took out a battery and inserted it in. Tap the switch and saw the neutral white tint and I went, "Gosh! Super bright Nichia 219!" This got my attention! That's right guys, the tint from this light (got the neutral white one) is so Nichia 219 like I couldn't believe my eyes! It is an XM-L2 in there alright and then I was suddenly impressed. Compared it side by side to the Fenix PD35 TAC which is using an XP-L and I couldn't even tell a difference in the size of the hotspot. They both look the same even though the Thrunite is using an XM-L2 with a bigger die size and I was expecting a more floody beam profile. This light does throw reasonably well considering it is using such a small reflector (notice I said reasonably).
It tail stands great but at the expense of a deeper recessed switch (compared to the Fenix), thus making it a little harder to do momentary presses without sometimes pushing too deep and clicking it on instead. Guess I need to get used to the amount of strength to use when doing momentary presses.
Rear switch felt mushy and doesn't feel as robust and precise as the one from Fenix. The new metallic side switch felt good, even better than the one on the Fenix. The side switch protrudes a little more than the Fenix and is easier to find. The Fenix side switch is almost flushed with the body of the light and is just hard to find. Can't imagine one trying to access the side switch on the Fenix when wearing gloves.
Mode spacing. I guess this is what everyone is interested in. I see many have complaint about the difference between Max and High to be like jumping off a cliff. Looking at the numbers on paper it would seem so, but in actual use, this is not the case. I find the difference to be very close. Remember that our eyes works in a logarithmic way and we would need at least a 2 to 3 times difference in output to actually see a real difference. On the other hand, the difference between low and medium is really like jumping off a cliff! This is my main pet peeve with Thrunite. It is nice that they provide a Firefly mode, but their low is a little too low, and their medium is a little too high. It was like this on their Neutron series, and it still is now. The manual claims the medium output to be at 145 lumens on medium, and 11 lumens on low (let's omit Firefly since it's a dedicated output). Between 11 lumens and 145 lumens is like 4.5 times difference in output! It is so obvious to the eyes. The low is too dim for proper close up work, especially with aging eyes like mine, and medium is too high it is a little blinding! What were you thinking Thrunite?
As for the clip? It works well alright but felt a little bit loose compared to the ones provided by Fenix. I hate clip on clips but the ones on the Fenix PD35 TAC is real solid and tight, just not the Thrunite clips which tends to swivel around a bit too easily when turning the head or the tail cap. Kind of have a bad feeling that I will loose the clip one day when it decides to pop off the light when I am pocket carrying it.
Overall, I like it. It is nice for something that costs so little. I just hope that Thrunite would improve on those areas which I have mentioned and this light will be sweet!
