I'm confused. I see two versions of "warm white" (I hope) lights that Lowe's sells. So:
1) Do we know for sure which one of these two uses the warm Nichias?
2) Which is brighter?
3) Which has a nicer tint?
One:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=283278-82850-29112&lpage=none
Two:
http://www.lowes.com/lowes/lkn?action=productDetail&productId=283277-82850-29110&lpage=none
When I bought the puck kit at Lowe's there was a guy working in the lighting section who appearantly was into lights. When I mentioned to him that I wonder how those two lights would compare away from the display with all the other lights, he promptly snatched one of each off the shelf. We plugged each of the kits into the power outlet under his computer desk where it was semi-dark. The tint looked the same from both of these lights. As for brightness, it's hard to be truely objective without a meter. The pucks seem brighter though (alltogeter and similarly spaced, of course).
The pucks are far more practical to me. Extra wire is spooled inside a deep slot around the edge of each puck. One can neatly spool the wire up inside each puck to position them close or unspool the wire to position as far as 32" apart. I have 18" between my countertop and upper cabinets. I have tentatively mounted the three pucks 14" apart just to see the effect. Once I get the other kit, I think I'll place them 12" apart. It would be great if this kit was made as 6 single LED pucks instead of 3 doubles. That would be much more versatile. I would really prefer to have 3 LEDs under the left cabinet and 9 LEDs under the right, that would give me a more even distribution of light.
The bar, on the other hand, gives you one choice: 5 LEDs stuck in a 18" bar. You have no verstility to spread the LEDs apart to vary the intensity of light cast onto your countertop.
Of course, if you're just looking for Nichias to scavenge, then this info may not be helpful to you.
I don't know if these are Nichias or not. But I took closeup pics through a jewelers loupe so that someone more familiar can identify them.
I plan to go to Lowes today, so I'll try to remember to look at the bar's LEDs to see if they look the same.
You all can benefit from me paying the $50 for the puck kits. Good deal or not, my wife wants undercabinet lighting NOW! So for me, YES, it's worth it. I can just here it now, "Why do you have to bulild everything yourself? Why can't you just buy the ones at Lowe's? We don't have to have the best under cabinet lights known to man!"
