Does anyone really wear a light under their hats bill...I wear mine on top of the bill so it`s not in the way of my vision. Seems like common sense to me?
I just received an EA2 but the tube is a VERY TIGHT fit with my eneloops. I dare not insert them to try as I'm not sure if I can get them out.
Can the head be removed from the battery tube? I tried but couldn't or maybe I need to force a bit more?
Has anyone got the same problem with their EA2? I got it from Doing_outdoor on eBay.
Very frustrating!
Now i wonder, how will i know that im buying an EC2 from the later shipment, which they have made better?
As for EC2, in the early shipment part of lights escaped from QC.
Be on the lookout for fugitive Nitecores!
I've had my EC2 for over 2 months and either the light isn't as bright as it was (on a couple of levels) when I first received it or I mysterioulys over estimated the brightness levels when comparing the EC2 to the Eagletac D25LC2 twisty.
2 months ago I noted that the EC2 lowest low was visually brighter than the ET D25LC2 (I guesstimate the ET low at around 15-20 lumens) and that the EC2 turbo was visually brighter than the ET tubo (ET Turbo is a reported 343 lumens OTF).
When I was comparing the lights again a few days ago, the EC2s low is now clearly lower than the ETs low AND now the EC2s turbo is now visually dimmer than the ETs turbo. My gut tells me that the EC2s ouput somehow decreased but I have now way to prove it. I'm pleased by the apparent lower low and the turbo is still plenty bright (so maybe this has been a good thing), but I'm not sure what happened.
BTW, I had a real world use for both lights recently and I much prefer the beam pattern on the ET D25LC2 which has a pretty good spot with very useful spill...I much prefer the ETs beam pattern over the EC2.
I think it's always fair game to compare beams of lights you own in determining what beam/light you prefer (regardless of emitter or reflector) as that's about determining personal preference (some might prefer the more focused beam of the EC2 for their use). For clarification though, my D25LC2 twisty has a XPG-S2 emitter.I don't think it's fair to compare the D25LC2 XML floody 600 Lumen beam to the EC2 XPG 400 Lumen beam that has a big 1" reflector designed for throw.
Very bad experience, I am really interested in their EA4 but I will have to make sure it fits Eneloops.
I think similar problem would never happen with Zebralight. I wish the Q50 is released so I can forget this EA4 (once bitten twice shy)
I forgot to post an update. I'm not losing my mind, all levels continue to get noticeably dimmer over time...the turbo on my EC2 is pushing out some where around 150 lumens (maybe) and the lowest setting is really a moonlight mode now. Love the low getting lower but this thing is on a steady decline of output so it has to be returned.I've had my EC2 for over 2 months and either the light isn't as bright as it was (on a couple of levels) when I first received it or I mysterioulys over estimated the brightness levels when comparing the EC2 to the Eagletac D25LC2 twisty.
