markr6
- Joined
- Jul 16, 2012
- Messages
- 9,258
Decent, but a 31% is significant. I would even call 2000mAh "decent", but still warranting a joke
31% of what? It's not w battery commercial, it's just an information that P12 takes 18650 cells. I don't know why it's bothering you so much.
I will buy one if it has the blue low voltage indicator.
I am in strong agreement. In a light this size, this is better than xp-g level throw with xm-l level output. This is the first light on my "will probably buy" list in a long time. I can see how, if you don't care much about changing the bar on throw on an XM-L-based light this size, you might not be impressed overall
So if the number is true, it would be a real breakthrough and NITECORE should use XML instead of XPG in their future models to get both LM and LUX.
can't wait to see a compare to the pd35
Am I in the minority in thinking that any of the P series ("Precise") would be supremely desired if they were available with the interface of the E series* ("Explorer"), such as the EA4 or EC25?
Just read the user manual. Steps down after 3 min to a lower setting end quote. high is 950 lumens medium is 210 so I guess it steps to 210.
Granted, they wouldn't be "tactical" per se, but more compact side switchers.
I'm referring to the UI, not the literal switch.Which one, the EA4 and EC25's switches are different.
