jtr1962
You can vividly demonstrate this by putting a piece of black electrical tape over the dome of a Rebel or an XP-E/XP-G. The tape will start smoking almost immediately. On the other hand, do the same with a piece of white paper or clear tape, and nothing happens. This is telling me the dome doesn't get that hot in normal use. Rather, it is the emitted light energy being absorbed which makes some ( but not all ) objects placed near the dome get hot. And if you physically think about this it makes sense. Today's emitters can emit upwards of 100 lumens of light from a very tiny surface area. The efficacy of the emitted spectrum is around 330 lm/W, so 100 lumens equates to 100/330, or about 0.3 watts, of light energy. Think how a small component like a surface mount resistor gets when it dissipates 0.3 watts. And if you put a probe or black tape or your finger over the dome it will absorb roughly that much power. This is a relatively new, interesting phenomenon. A few years ago LED domes were much larger, and they emitted far less light, so the temperature rise experienced by objects in proximity to the dome was negligible.EDIT: What was most surprising for me, was the idea that the probe gets hot because of the radiation it absorbs. I always thought that when I touch the thermocouple to the LED dome, what I measure is the actual dome temperature, not the massive amount of radiation that would be needed to rise the probe temperature...
But the fact remains that nearly 100% of the heat an LED produces is conducted to the thermal pad. Oil cooling of the dome will accomplish absolutely nothing.
