Sold/Expired P60 modules - warm, neutral, cool white/XPG-S2- XML-U2 / P60 modules (part 9)
Status
Not open for further replies.
Stillphoto
Orange County
Re: P60 modules - warm, neutral, cool white/XPG- XML / SST-50 -90 P60 modules (part 9
I have a P60 capable body that runs 2xAA batteries. It had a malkoff M30WF in it until I was made an offer I couldn't refuse. So I'm looking for a neutral (or warm, but I'd prefer to stay away from 3000k) drop in that'll run on 2 standard lithium energizers (this is my back up light that stays in my glove box). Can have a reflector or optic, doesn't really matter, doesn't need to be floody like the malkoff was. Any suggestions?
nailbender
North Carolina
What is the advantage of the U2 XML? Is it more efficient or more lumens? My NB T5 3C XML's look way better to my eye than some of the cooler drop-ins.
HI
More lumens is it and not near as many more as some want to promote. It is much like going from a R4 to a R5 or maybe a R4 to a S2 if we were comparing XPG's. The 1A is not terribly coolwhite like a 1T is but if you are satisfied with the tint of a 3C I would stick to that. If I wanted a FEW more lumens I do now have the 3C in a T6 instead of a T5 which is one of Cree's newer options for a 5000k emitter. Also while the U2 is the newest offering flux wise and is very efficient the U2 has a higher VF at about 3.5 or 3.6 volts compared to T6 or T5 which are a little bit lower.
Thanks
Dave
nailbender
North Carolina
HI
I only have one driver that will work with 2XAA, it has 5 levels and will only work with an XPG. I have neutral and warm but since most warm whites don't start until about 3000k or 3500k I would stay with a neutral R4 5B2 tint which is 4000k.
Dave
yellow
Baden.at
received the module yesterday,
hell ofa bright!
the 3C is an extremely nice color/tint
nailbender
North Carolina
hell ofa bright!
Hi
Great! I am glad you like it and I agree with you it is a great tint.
Dave
thaugen
USA
Hello Dave,
I would like 1:
Cree XM-L $40
T50 flux Bin 4A 4500K neutral white
3 level Low / Med / High Regulated with Memory
2.8 amps
LOp reflector
Potting with copper tape + $5
For use with AW 18650 in Surefire 6P or C2Thanks!
Halibut
Costa Mesa, CA
Cree XM-L
T6 flux Bin 3C 5000K daylight
2.8A, regulated
LOP reflector
Potting with tape
$45
Host: TnC 26650
Battery: IMR 26650
:paypal:
Mr. Tone
Illinois
Nailbender, I will take 2 drop-ins. Here are the details of what I want.
XML 2.8-6 volt T60 flux bin 3C 5000k daylight white
3 level Low / Med / High Regulated 2.8 amp with memory
OP reflector
$40 drop-in + $5potting=$45
XPG Q23000K 7A3(90 minimum CRI) NEW
3 level high / med / low 2.8-6 volts with memory / 1.4 amp
OP reflector
Drop-in $35 + $5 potting=$40
1xXML potted + 1xXPG potted +$5 priority shipping=$90
RCantor
KC, MO
Do you have any XREs with a 3c or 4x tint bin? (since you hinted you had alternatives)
D
Deleted member 97529
Guest
Hi Nailbender, are your XR-Es and XP-Es EZ900 or EZ1000?
RCantor
KC, MO
OK, then, with all my pestering, this is what I want. The first item is a D36 so I'll post this in the other thread, too.
_____________________________________________________________
D36 D36 XML potted T50 flux Bin 4A 4500K neutral white for FM's 1*32650 D36 host
3 level Low / Med / High Regulated SMO $45
P60 Dual XPG potted Q23000K 7A3 (90 minimum CRI) for Solarforce host $50
3 level Low / Med / High Regulated 2.8 amp Thanks for the tip on Phazerburn's diffusion film - it worked really well!
P60 XRE
Q3 4C smo potted 1.4 A 1 level for solarforce host $35
P60 XRE
Q3 4C 8 degr optic potted 1.4 A 1 level for solarforce host $35
For a grand total of $173 with PP fees, right? (PP sent but we can alter it if needed)
RCantor
KC, MO
Oh, for my dual xpg, since I'm going to use the film, would a smo reflector be better? Unless you have misgivings lets go for smo. If you have any advice I'd be happy to hear it :)
psychbeat
SF norcal
sending PP for T5 neutral XM-L
2 mode pushed 3.1 LOP potted please!
45$
going to be used in a p60 Headlamp host that has lots of fins and on my
bike mostly so should be cool enough.
Using a 1s4p 18650 pack so 3.1a is no problem ;)
thanks!!!!
psychbeat
SF norcal
Heya- if not too late I'll take an SMO reflector instead -as I've got a few LOPs chilling in my parts box ;)
The XM-L seems fine ring-wise
ODatsBright
Cambridge, MD
My XM-L DBS pill arrived today and I have to say I'm thrilled with the 3000K color temp. I find I'm really moving away from any of the cooler color LED's. I can't wait for night to arrive, people will think I'm crazy but oh well. LOL
Thanks Nailbender!
D
Guest
Hiya, before I send paypal, please check if everything is possible and available:
LED: Cree UV XL 7090 $45 (395nm)
Reflector: LOP
Driver: 1 level 2.8-6 volts 1.4A
Potting + copper tape $5
LED: Cree XM-L $40 T60 flux bin 3C 5000k daylight white
Reflector: LOP
Driver: 1 level 3x Li-ion ~700ma (are these available?)
Total: $95
Thank you!
nailbender
North Carolina
Thanks Nailbender!
Hi
I thought you would like it since you said you were getting away from coolwhite. I think it is even more incan like than the 45k SST 50's. I am glad you are pleased
On another note. Psychbeat and Rcantor smooth is not a problem as long as my senility doesn't set in:)
Dave
nailbender
North Carolina
Reflector: LOP
Reflector: LOP
Total: $95
Thank you!
Hi
I usually I only push the UV's at about 1 -1.2 amps as the specs from Cree are 700ma so 1.2 amps is about tops.
Now for the XML, I have a one level 1 amp that will accept 3X LI ions, I don't have any 700mah available in high voltage as I have very few calls for a driver with that low of amperage.
Dave
Status
