You guys... quit twisting my arm!My guess (which is just that since I have not done this mod myself) would be that an SSC P4 U bin would be about 60 lumens on High in the EOS. I figure my R bin LuxI light is 32 lumens on high, so just about double that for the Seoul.
Nice writeup and pictures. Seems straightforward to follow. Still...
Anybody want to sell me a pre-modded EOS? One that follows the specs above would be perfect. PM me. Thanks!
Whoops, you're correct. Updated the writeup. Thanks!
-tibim
Hi!:wave:
At me 3 questions.:candle:
1. In Princeton Tec EOS is mounted Lumileds (Philips) Luxeon LXHL-MW1D?
2. If it so, why Princeton Tec informs about 25lm, and you write about 32lm?
According to the documentation, LXHL-MW1D has 45lm at 350ma.
3. What current (in ma) flows through LED In a mode of the maximal brightness?
Thank for the answer.
If I correctly have understood (English not my native language),
Princeton Tec is insured, underestimating the declared brightness in 25lm.
I studied the documentation (datasheet) on Luxeon LXHL-MW1D, but where has not found BIN-marks on him. About what there is a speech?
I have EOS and Apex. The measurements with the help of a ruler and calculator have given:
EOS - 7 degrees Width Beam
Apex - 18 degrees Width Beam.
The brightness at the centre, approximately, is identical.
Also it would be desirable to learn, what optics uses Princeton Tec in EOS and Apex.
Why reflector the lenses are better?
