Princeton Tec seems to be one of the few manufactures that are using true out the front Lumens. :thumbsup:
Soldering is the easiest and fastst part of this mod. Breaking open the case and fooling with the reflector is harder. The P4 Star alread have solder blobs. So all you need to do is hold the wire on top and touch it with a soldering iron for a sec or two. Practice on some resistors from an old circuit board.
Which reflector did you use Avro? SMooth or stippled?
I just received my PT EOS and I've just been testing it against my Myo XP in a dark room. It's actually brighter than the 3w XP, but it has no "spill" like the XP. After seeing the "beamshots" of the modified EOSs, I just ordered 2x Seoul SSC P4s to modify my EOS. I see that the Fenix reflectors are all gone, so I'd like to get the afore mentioned Khatod 17 reflector, but I do not know how to go about finding these. Does someone have a direct link to a sellers Khatod 17 page?
coors
This seems to be the most common mod boo boo for the EOS.
Try it with the sensor open circuit.
