Fallingwater
Rheslip: Could you tell me about this Zetex stepup converter? Where do I get it, or how do I build it?
What part is the transistor you used in place of the existing one?
Also: where did you get the Arc clones?
Edit: oh good, I broke one of the inductor wires as I was installing the pellet in the plastic sleeve.
Now I have the broken pellet inside the plastic sleeve. I need to remove it to resolder it without completely ripping the inductor off.
As if that wasn't bad enough, some cyanoacrilate glue (which I used to keep the positive metal contact of the sleeve in place) trickled down to a wire and how the thing doesn't want to come off.
Argh!
Edit2: I'll have to drill through the wire. It'll have to wait for tomorrow, as the dremel is a bit noisy to run at 3.30 am.
Argh!
