Sofirn SC13 First Impressions
jon_slider
Sofirn provided me this Review Sample free of charge.
User Interface:
My Lumen Meter, which is not exact, gives some idea of the modes.
Hold from off: 1 lumen (not memorised)
from On, hold cycles 3 main modes (will memorize at turn off)
8 lumens
122 lumens
330 lumens
double clic (from off and from on) 800 lumens (not memorized)
from 800 lumens, double clic to strobe (not memorized)
Features:
When first turned ON the button LED glows Green for 5 seconds with a full battery
has tailmagnet
weight 62 grams w stock 18350 and clip
switch button is on a raised platform that protrudes from the head
the USB-C charge port cover is also on a raised platform, on the opposite side of the switch.
I can find the button by feel in the dark, it is not illuminated.
stock battery is button top,
there is physical reverse polarity protection
my flat top keeppower 18350 also works, which means the light can serve as a travel charger and backup battery carrier for my 18350 and 16340 lights
During Charging the button LED is Red. Charge rate starts at 0.74A and drops to 0.42A as the battery nears full charge.
The button light turns green and charging shuts off, when the battery reaches 4.2V.
Opple 3 data for the SST-40 6000K:
CCT 5700K
CRI 61
DUV 0.0127
1 lumen mode has very low PFM, (Pulse Frequency Modulation), about 2% fluctuation, that produces a very Low Flicker Index of 0.0040.
8 lumens mode has 96% fluctuation and produces a High Flicker Index of 0.5838.
No visible PWM because the frequency of the pulses is very fast, about 40KHz
Modability: not easy to open without damage.
There is a press fit bezel and it would need to be pried out to remove the lens and access the LED.
I can get my fingernail under the bezel lip, but was unable to lift it using automotive plastic tools for door panel removal. A blade or small screwdriver might work, but will probably leave marks in the anodising.
What I like:
Nice small form factor with a contoured waist that works well for cigar grip.
Easy UI and useful beam w large floody hotspot.
Built in charging works for both 16340 and 18350
What I would change:
The LED is Low CRI
jon_slider
Decided to change the LED, since Im not a fan of Low CRI:
but this was the greenest 519a Ive seen and I was not satisfied, so decided to Dedome it:
the light is difficult to open, because the bezel is pressed in.. took a lot of hammering to get a screwdriver to lift the bezel.. not pretty:
so I disguised the damage by polishing the bezel:
Suprisingly, despite many hammer blows, the light still works.. but its not a mod I would recommend..
the Tint now looks like this:
sometimes things dont go as smoothly as hoped. ;-)
the dedomed 519a is not a good match for the flat Tir..
I much prefer modding the Sofirn SC21 Pro.. the bezel is screwed in, no hammer needed.. LOL
vicv
Southern Ontario
Might need a bit of dc fix to smooth out that beam. Jump from low to med is pretty big too. And med to high is too small. A ~60ish lumen medium would be better. Still not bad. How is the regulation? Sofirn is weird. The sc21 is excellent. Then the hs10 which is basically the right angle version, is non existent
jon_slider
hs10 is still available
much easier to open for modding, the bezel is screwed in
I dont think much of the mode spacing.. Im spoiled by ramping UI's.. the HS10 does have a ramping mode
but the driver is not regulated.. for that I buy the Emisar D2
vicv
Southern Ontario
And converting to our less valuable Canadian dollar, it's closer to $70
Edit. I see the confusion. When I said, HS 10 is nonexistent, I meant the regulation on it. There isn't any. Which is a shame because the SC 21 is basically the same thing and it's excellent. Me saying it's pricey was talking about the Emisar D2.
jon_slider
oh, yes, D2 is expensive.. it IS two lights in one, it has Anduril, and it is regulated.. but yeah... money
The D2 is also Very picky about batteries, it will NOT work w the TS10 battery.. which is why I hesitate to give a full recommendation of the D2
And yes the SC21 MINI IS regulated, and inexpensive, and easy to LED swap
fwiw, I believe the SC21 series is being discontinued..
vicv
Southern Ontario
Ya. Looks good though. As to the sc21, looks good but the ts10 covers those needs. Think I need to get a headlight next. My last purchase hasn't even arrived yet. Lol
jon_slider
headlight
the Skilhunt H150, is regulated, accepts AA as well as 14500 (including the TS10 battery), has built in charging (proprietary magnetic cable), includes a headband (D2 does not)
otoh, the H150 switch button sticks up, makes it easier to use, but requires lockout imo (I unscrew the tail)
vicv
Southern Ontario
Thanks. I was looking at more the h05f. But I'll look at that one too. Skilhunt seems to do dual fuel well as well
vicv
Southern Ontario
H04F is 18650, MUCH better runtime than the H150
but afaik the Skilhunt is not potted.. which is why an Armytek or a Zebra could be a better option.. some discussion here
I meant the mini. Doh. Ho4f mini is the one I have my eye on. Want light weight as it'll be used for short times.
Don't care about potted really. Won't be using it as a baseball.
Sorry we've totally derailed your thread. It's an excellent review
jon_slider
I dont mind at all. I enjoy sharing info w you
the mini has a great reputation.. I trust you will enjoy it.. though I have no experience w it, I trust Skilhunt.. my H150 seems like a solid, reliable light..
It mostly lives in my car emergency kit.. fortunately, Ive not had any emergencies. ;-)
the main reason I went w the H150 is because I want the ability to use AA if the LiIon freeze (it snows here), or also because LiIon lose charge in Summer heat in a car. (we reach 90F).
vicv
Southern Ontario
Good me too. That's a good reason. I hope you're using an energizer lithium in there. Alkaline isn't much better for high and low temps than lithium ion. My vehicle light is a convoy m1 I built with an sst-20 4000k and a buck driver at 1A loaded with 2x cr123a for low and high temps. The headlight would be for playing fetch with dog at night. Bbqing. Short walks with a throwy light in my hand. Ect
jon_slider
yes, actually, as a test It is loaded w its LiIon, and I have a battery case w an Eneloop and a pair of Lithium Primary as backups:
we think alike, though I avoid dual battery configurations, my emergency kit in my snowshoeing backpack is a Novatac w a raised tail button, loaded w a single CR123a, and a battery case w a couple spare CR123a.
the winter light has a raised button, for ease with gloves on:
vicv
Southern Ontario
Nice set up. Personally, I think the CR 123 danger is a bit overblown. I only use made in USA Panasonic cells, from the same batch, and I never mix them. And I don't run my lights until they are so dim you can't see anything. There is some risk, but I think it's small enough that it's worth it. But I do agree that it's even safer if you only stick to having one.
jon_slider
I never mix them
good strategy ;-)
I believe these lights exploded due to mismatched voltage of dual CR123a batteries.. not positive, but I avoid dual batteries because of it:
vicv
Southern Ontario
good strategy ;-)
You are correct that is the reason why that incident happened. As long as you don't have mismatched cells, it's not a problem. Obviously, each person has to decide on their own comfortable amount of risk. That incident also made everyone terrified of Olight. Even though it had nothing to do with the company.
