degarb
I read the Moto 360 smart watch uses a custom qi receiver. So, a flashlight maker might look to what they are doing with tiny qi receivers.
The blue cap came along with a newer batch. The black cap with the rubber boot USB designation misspelled as "USD" was the original production. That was corrected in later batches, perhaps with attention to other issues they had missed in the first.
It doesn't take much to unscrew tail cap to prevent parasitic drain. It always seemed a practice that would defeat the purpose of o-rings and waterproof claims.
Is bang good selling the first "usd" batch?
Probably, would buy several more, (if glued in properly) at $30 level. Maybe, 3 or 4.
On a side note, this isn't my first single 18650,infinitely variable headlamp.
There is my http://m.gearbest.com/headlights/pp_251155.html which ramps infinitely, uses a tir for throw, xpg. However, the aluminum Composite is heavy like steel, optic is inferior, larger head, poor runtime using it. The electronic variability is inferior to a mechanical ring as it constantly forgets setting, especially after lockout. I strapped it to my sweeper, taking my Boruit RJ - 02 R5 out of regular use. But, at the price, not a bad light.
62,000 cd. oo: Bet you could slice butter with that beam!
Luminous Flux: 300Lm
Color Temperature: 5500K
Switch Type: Clicky
Battery Type: 18650
Waterproof: IP-65 Standard Waterproof
Working Time: 4h (max)
Lens: Plastic Convex Lens
:hahaha:Beam Distance: 400-500m
Body Material: Aluminium Alloy
it uses 1/3 of a copper star. 1/3 of the top and 1/3 of the bottom is cut off to make room for all the wires inside it.
HR20 XP-L is really good headlamp. I use this model since 5 years and is working without any problems. I need one more, someone can recommend something?
They claim 62k cd?
They claim 200 meter throw. Hotspot is intense, so i dont doubt 0,25 lux at 200 meters.
