I cleaned up my threads with sandpaper. Still having to hand tighten tube every day to stop flicker caused by electrical contact. Variable resitor endemically may cause flicker, since it is just a brush touching a metal ring with wedge of varying resistance. Using these, playing with dial, fixes the innate flicker. Apart from threads, I don't think the temporary flicker is a manufacturing flaw, just a feature,state of the art. Probably a real buck, since based on my lux/runtime test, it ain't cc, but clearly regulated. Then i never been impressed with the cc of amc7135,which is linear. But this is less cc, even.
I need cc for extreme detail inspection at work. Don't need cc for home and recreation. I am using these hr20 for home, recreation, and backup (forgetting to bring my home built 700ma to xpl v6 nw in a 35mm via buckpuck off 2p18650 balanced in rear. What bothers me the most about this light is the wasteful 20 mm smo. With a 26 mm and xplhi, i can work and inspect just as well at a fraction of the current. Hotspots don't need to exceed 12 degrees, 15 in theory, based on cone distribution. More, wasted precious runtime.
Maybe someday someone will redo this light with a true cc and 555 timer, and allow a 24 or 26 mm smo with ar glass to inter change the 20 mm smo. Yeah if i only camped or read with the light i would make or buy a red or clear diffuser.
I probably will never again buy a manufactured light simply because that target of 10 hours, workday, at 1k lux minimum at 2 meters, seems so hard for people to grasp. At least, ramping light levels, infinitely variable will allow me to find the correct level without idiotic 10,30,100 defaults that simply are usually too dim or too short runtime. Only the hp11 ever stumbled on a correct lux and runtime level of 4 k candela for 9 hours cc. And it came with a diffuser,which protected lens during transport. Old tech, but still using the lights, despite my 300 lumen 5400 candela 9.5 hour builds, simply because as long as most eye cones are covered with hotspot at 1000 reflected lux, this is what is important for task lighting. Reading, navigation, jogging, camping, folding clothes, flood is the ticket. Just don't like the drive level, nor led bin, choices of the hp25 from fenix.
