So you're saying you tested them and put them through more than 500 cycles? At the rates you mentioned, that's over 6 months worth of cycling the cells strait (with the 2 hour resting period only after both a charge and discharge or discharge and charge cycle, more if they rested between each phase), while taking into account their diminishing capacity down to 1960mAh (80% capacity).
Either way, I don't think this accurately reflects their more common uses, shelf aging, and real world application cycle life expectancy.
I still prefer the "1500" cycle "2000" mAh Eneloops, which should have a cumulative lifetime capacity total of about 2.4 times that of the XX cells. I'll take the 2.4x cumulative capacity of the "1500" cycle Eneloops over the 1.25x per use capacity of the XX cells.
