Those numbers are all well and good, but they are irrelevant. You simply won't draw that much battery current with the MD60. It clearly uses a buck driver and the battery current draw will scale with Vbatt/Vf.
As I wrote before, if anything the nailbender tower is less suited to 2S 18650 than the Malkoff MD60. Because the MD60 lower voltage limit (presumably for full regulation) is 6.5V, when each cell reaches ~3.2V under load, the light will start to dim because it has fallen out of regulation. This is an indication to change our your cells and serves as an excellent visual indicator to protect your cells from overdischarge. At that Vbatt level, Ibatt might be an estimated 1.2A-1.4A. Pretty mild draw -- around 0.5C for your typical 18650 these days.
In contrast, at the nailbender tower's min voltage of 3.4V, you will basically run down your cells until they croak or the cell's protection circuit trips to protect against overdischarge. That is far less kind treatment to Li-ions.
Edit: I want to clarify that I personally don't find either tower specs to be a hindrance wrt using 2S 18650 and I would be comfortable owning and using both products. But you have to understand the impact of the specs operationally. A low driver voltage to stay in regulation is great if you want to have the flexibility to use 1xLi-ion as well as multiple Li-ions. The nailbender tower looks like it is very suitable for that, while the MD60 is not. However, when it comes to 2xLi-ion, the Malkoff is the more forgiving product IMO because of the reduced likelihood of overdischarging the cells. But that also depends on your usage pattern. If you use your light for some known amount of time per day, for example, then it should be relatively easy to keep track of run time and re-charge the cells periodically to avoid overdischarge. But if you are not so diligent or it is not so convenient to track run time, then you have to assess whether this is an important issue or not and factor that into your selection criteria.
