ah.. it seems i got it wrong. p1 and p2 can't be changed? i managed to go to sw2 and changed its p1 to my desired brightness. the p2 in sw2 is not a mode but only for changing p1's brightness? gosh this light is confusing but im sure i will like it when all these are sorted out
dont fret! okay
slow down.
you have the instrcutions right? get them...
when they say "SW" it means switching from P1 to P2 and back to P1.
so..when they say 3 x SW it means switching from P1, to P2, back to P1, again to P2,back to P1, again to P2, and back to P1 again.
assuming you did that three times, it would take you into default strobe mode.
Programming is the same, you just have to follow the flowchart, and use the number of switches specified.
and when you are adjusting a particular level...
P1 fixes the point
P2 increases/decreases the output. to fix it, swtich back to P1.
if the output is increasing while youre in P2 and you want it to decrease, you do this..
Go back to P1.
From P1, do 2 x SW (P1, to P2, back to P1, again to P2, back to P1)
youre back at P1.
from there, if you switch to P2 the light will start decreaseing ( or increaseing if you last had it in decreasing)
i hope that made some sense..
Crenshaw
