EscapeVelocity
- Joined
- Jan 1, 2009
- Messages
- 343
Here is the inventory.
1 3D Red
1 5D Black
1 6C Black
2 6C not operational.
These are all older models with the older heads.
So far I have picked up
One 5 Cell Maglite Xenon Bulb
One Terraflux 140 Lumen 6EX for 4-6 Cell Maglite LED bulb
One Terraflux 140 Lumen 6EXB for 2-3 Cell Maglite LEd bulb
One Craftsman Variable Power LED Replacement bulb - not here yet
I really liked the Terraflux bulbs. The Xenon bulb was not impressive. I also have several Krypton bulbs original to the units.
I was thinking of getting these to try out too, as I am also just playing around abit...
Nite Ize 1 watt LED Replacement Bulb for C and D (Could be used for other non-Mag flashlights as well)
OEM Maglite LED Upgrade bulbs (Check these out against the Terrafluxes) These are Luxeon Rebels?
Fusiion 36 LED Module - Not sure if these fit the older Mags
Terraflux 310EX-M - Not sure if these fit the older Mags (I dont think they do) However Im pretty happy with the 140 lumen Terraflux bulbs.
I would also like to pick up some metal, cammed if possible, reflectors for these uits. Anybody got a line on these?
Also some Pyrex or Boro or other glass lenses to replace the OEM plastic ones. Where can you get these?
Question: are most of these bulbs usable in other non-Mag flashlights? They have the same standardized form factor (besides the screw in type), right?
Also interested in the ROP mod and prefab AA carriages for D cell tubes, but that is for later.
The two 6 C fixers, one has fused corroded batteries in the tube and the switch is jammed forward, plus a broken reflector. The other Ive loaded up with batteries and known good bulbs but cant get light. Both are missing the rubber boots for the switches. Any tips on what to do with these? Send one or both in for Lifetime Warranty?
Thanks! Ive got a bit of the flashlight bug reading the forums here!
1 3D Red
1 5D Black
1 6C Black
