Chief-Yeah
It is a normal amount of time to machine a titanium part of this size and complexity. I have pushed all the tools until they break and then backed off.
Still, I have to pull all the tools out and check them every cycle or so.
It could be done ~25% faster if you throw enough money and time at it, say another couple hundred $K. Titanium aerospace parts like spacecraft parts and fighter airplane parts are made the same way I make the 007. They usually use high end machines that get $250 plus per hour not including tooling and setup costs.
If the item's production is in the thousands of copies, then a casting can be a good solution as you see in titanium hand guns. I have three cast titanium 005 bodies that were made in Canada a couple years back but they were not right, so I never finished them out. Cast parts also often have voids that make some percent of the parts unusable.
Titanium is one of the most amazing metals on the planet. But machining it takes time.
Cheers
Dave
mind if I ask what cad/cam software you're using ? I'm a former CNC'er (10yrs) and I'm currently looking into getting a tool room mill and I'd just like to see what the general consensus is,thanks.
