ElectronGuru
An easy way to increase torque is 'handedness'. If you need 1 hand to grip the tool, that leaves you with only 1 hand to grip the bezel. 0 hands for the tool and you double your grip on the bezel.
i dont see any retaining ring on mine. incan 6p.
it's seriously gotta be glued in like crazy
Vintage 6P bezels have snap in lenses. These usually lack the hex of bezels made only in the last decade.
The snap in design requires a plastic lens than can bend upon insertion. These were available as Z17 kits, but no longer. Glass lens cannot bend and so cannot be used in these bezels. You'll need to replace the bezel with retainer ring compatible setup. The closest current option is the smoothie bezel.
what's a good one that has good thermal properties that still fits a P60 dropin? or do all of them fit the P60s?
Pretty much any bezel out there is made to be Z44 compatible, fitting 1) 6P style bodies, 2) Z44 bezel rings/lenses, and 3) P60 drop ins. The only exception I can think of, the cryos 2 uses larger lens/rings, but still works with 1&2 and there is also the cryos 1 that works with 1, 2, and 3. SF Z44 bezels (hex) and the smoothie (no hex) are direct replacements for your current bezel, also supporting 1, 2, and 3.
