Absolutely. Not quite night and day, but the difference is immediately obvious.
Where can I buy the Dereelight SMO module?
Would that be my best choice if I wanted maximum throw on a Surefire G2L?
BIG difference.Sig Sauer said:The E2DL has the same max output as my Novatac 120. Is there much difference in the throw between them?
Significantly better, yes.Sig Sauer said:I already got a Surefire G2L at home. What if I replaced it with a M60? Would that have a better throw than the Novatac 120?
Debatable, but I'd probably give the nod to the E2DL. The big advantage of the E2DL is the large spot it throws (the spot from my E2DL is twice the diameter of the spot from my M60).Sig Sauer said:Would you say that the E2DL has better throw than a G2L with a M60 installed?
Go to the Dereelight modules page, pick up a 1SM-2 and leave the E2DL in the dust in terms of overall output and throw. Seriously.
I assume it's the same output on high, but Dereelight doesn't tend to give ratings for its modeules so I don't know for sure.
With the three-mode, however, you might want to also get a clickie tailcap. Switching modes with only a momentary/twist-on tailcap is not gonna work too well.
1SM-2 + SMO reflector
You can get both the OP and SMO reflectors for a few dollars more if you want to experiment. That's what I did but honestly, if/when I buy another one, I wouldn't spend the extra money for the OP reflector.
SMO: smooth, more beam artifacts but usually better at throwing the light
OP: orange peel, generally have a nicer beam but can't throw the light as well as SMO reflector
Agreed - the T1 is rather bulky for it's output. It's amazing how far things have come since then when you compare the likes of the E2DL to the 6PT.The best throwing 2 cells flashlight surefire ever made must be the 6pt, with a 3" turbohead. I have one, and it's very narrow beam is quite spectacular, but not very useful. Anyway, production of this model has ceased a long time ago.
