Looking like $65 for the reflector
Bezel tool is going to be $17-18
Still working on the silicon, there is a minimum order and I am guessing I would need about 20 people who wanted it for sure before I could order...and that is going to be about $4-5 add.
I kinda feel like some explanation' is due for the reflector. The reflector is two parts, and they consist of a CNC machined "mount" and the actual "electroformed reflector". Then the two are then bonded. This allows the best possible fit and performance, while retaining durability. Its a little more costly, but performance is top notch as you can see.
The bezel tool will be made from Acetron, fiber reinforced Delrin. The material itself has qualities that make it perfect for this use. It is strong enough to remove the bezel while not deforming and ruining the tool, and safe enough not to damage the HA finish.
As far as the silicon I feel its important, some may not for whatever reason. Foam doesnt last forever, the silicon should unless you melt it some how with 600 degree plus heat
. I figure for $5 bucks its a no brainer and it adds to the durability of the M6 while running 1909, WA 1185, etc.
