While we're at it, I would also throw in red and green colored filters and why not offer both tailstand and tactical type switches?
I quoted this to tell you that if it can tailstand, it's no longer tactical as the tailcap can't be recessed. Then I realized what you were saying.
Now I just want to tell you to go get an E2DL and when it's dark and your sock hunting, just press the bezel against your shirt and cycle the modes to save some night vision.
I would like to see the lumens ramped WAAAAAAY up, and the strobe brightness ramped up as well. 1000+ lumens for the HIGH, 300 for low, and 3000- - 5000 lumens for the Strobe.
This would fill my needs perfectly.
That's a beast.
A well designed multi-mode light will never make you guess what mode it will turn on. You will KNOW which mode it will turn on when you hit the switch.
Hence the beauty of the two-position head. Set it and forget it, and it works exactly like a single mode KISS light. But if you ever need it, that second mode is always there, just a 1/4 twist away...
Exactly.
Multi-modes are EXTREMELY tactical... as long as you can't cycle the modes through the tailcap.
The TK10 is one of the best examples I've ever seen. The beam is perfect for clearing rooms and then clearing something a bit larger. It can blind someone and still show you everything around them. It has two modes but I can press that tailcap as many times as I want in a half minutes and it's still going to be in the same mode.
Has a strobe? Cool, but you can't cycle the modes to get to it so how are you going to use it? Using the selector ring?
One thing people overlook is that ever though a flashlight has a selector ring, or you can twist the bezel to change modes, when and how are you going to change the mode with a handgun under stress? Have a weapon mounted light that you plan on twisting the bezel would be a lot easier for obvious reasons.
Strobe for instance. It has a selector ring that put's it in a momentary and constant mode by pressing or clicking the tailcap. Great.
In Law Enforcement when you pull a gun you have to be in the mindset your going to shoot it. You are, unless the subject changes whatever set you off real quick.
If you have a flashlight and a gun pointed at someone, it will get you killed to be strobing them if they are that big of a threat. How are you going to accurately see what they are doing? If you shoot and try to articulate your use of force, I hope you knew exactly what they were doing while everything was blinking.
If it's a drunk however, then it would be hilarious and beneficial.
You can have a strobe but don't expect you use it if you're paired with a handgun. It's not only stupid but impractical.
Even with a weapon-mounted light on a rifle. If you are aimed at someone, then why would you take attention away just to strobe them? Even if you can do it without looking. It's a serious situation where you need to be able to see exactly what they are doing.
And if the bullets fly and you're stuck in a strobe mode, good luck trying to see what's happening or change back to get a fix on things.
It would however be smart to change from a high to a lower mode (by ring or twist of the bezel) if you went from outdoors to indoors. It's taught in some low-light schools that there can be too much light indoors.
Having a selector ring would be beneficial. High mode for outdoors, slightly lower indoors, very low for searching a car or something. It's really all how it's setup.
Strobe has a use on a tactical light by use of a twist of the bezel or selector ring. Changing modes also does. You just have to know when to use them and when to just use the light for what it is designed to do originally.
Now, good luck trying to find anyone sensible in Law Enforcement who wouldn't slap you silly for having a strobe on a tactical light. Many would expect you to get people killed.
