treek13
Chris,
I am a big fan of your products but not of those darn Zoomerang polls.
That said, I would strongly recommend going with 123's over cr2's as a power source. The 123's are more readily available in general and there are more sources for low-priced, high-quality 123's than there are for cr2's.
Also, 123's have a huge advantage in energy-density over the cr2's. For example check out these Run-Time Plots - Fire~Fly II-CR2 by Roy and this_is_nascar. Roy's Fire~Fly runs three times as long with a 123 as it does with a cr2. TIN gets a bit over twice the runtime with a 123 as he does with a cr2. The slightly smaller size of the cr2 just doesn't make up for its disadvantages.
For similar reasons, I would also recommend sticking with AAA powered lights over n-cell powered ones. AAA's are cheaper, easier to come by, and store more energy than n-cells. Rechargeable AAA's are much easier to find than rechargeable n-cells and don't require any adaptor or special charger. Also, you can now get lithium AAA's. The slightly shorter length of the n-cell just doesn't make up for the advantages of the AAA (plus the AAA is thinner).
Pat
Pat
