Thanks for the link but help me to read it in English please. I cant even get google translate to fix it for me.
Hi light. Just look at the links in the third post Mikl linked to. It says the cells were discharged at 2A down to 0.9V. That's all you really need to know.
As I said earlier, in the past enloops have shown that they are capable of holding voltage better under load than the Chinese version(s) LSD cells. This is shown in the second graph, as the eneloop holds a slight edge in this regard. Also, as I said before, any capacity advantage these type cells have demonstrated under moderate loads in past tests, is likely lost after cycling 25 times or so and/or 3-6 months of actual use.
I'm not suggesting that these may not be good cells, they
are likely better than "traditional" NiMh cells, but in the long run eneloops have always been shown to be a better option, at least for medium to high current drain applications. For low current drain applications, these cells may have some advantage.
Dave
Edit to add, you might want to check out one of the links to the right in that thread. there's a
really nice picture of a, er, um, cat.
