Unfortunately all first runs are sold out. Just send me an email to mobile1 aat gmx.ch if you want me to notify you when I open sign up for a second run. So far there is interest for about 25 more lights.
Then the Weekly Progress Report:
We got the circuit boards - here is a photo - we got a good deal where 500 cost almost as much as 50, so we ordered 500
:rock:
Then this week we mostly tested the board in a fully assembled unit. The circuit board is working fine - however at Full POWER the light gets hot if you leave it on continuesly. So we most likely turn down the brightness to a reasonable level when we send out the lights.
If you want FULL POWER, less runtime, and a light that gets hot you can turn it up with a simple screwdriver.
Something that puzzled me is that I have another light here from someone else, that claims the same specs LuxIII @ 1000mA. The light is quite a bit larger, but has the same heatsink area - but doesnt get as warm (however it doesnt look as bright neither). The GatLight actually has 1000mA at the LED, it almost looks like this other light doesnt really deliver what it claims...
Anyway back to the GatLight At the moment we are still tweaking and testing the board - for example we try to make a unique feature work that should increase runtime by 15% (once we can make it work and once we get a patent pending on it I can tell you more about that one - if we can make it work)
Then the other big thing this week was the optics. Remember we wanted to use the NX05 which Lumileds on its specsheet claims works for all Luxeon products. While trying to get some ray data :thinking: (for another flashlight) I was able to talk to an optical engineer, who told me that the NX05 is not ideal with a LuxIII Lamberitan Dome, since the NX05 is optimized for the Batwing!!!!
:thinking::tsk::mecry:
I wonder how many know about that since no specsheet tells you that. At that point in time we already bought the 40 NX05. So we sent those back and checked every optic that is out there, we have had optics from Finnland, UK and the US. We finally found one, specifically optimized for the Lambertian LuxIII. This new optic produces a much prettier beam pattern then the NX05 and the front water seal is now even tighter. We expect the 40 new optics to be here this coming Tuesday.
Tuesday we should also expect the rods and center housing (with engraved serial numbers). The Titanium rods took a bit longer. The machine shop had to redo the titanium rods at their costs (they are really hard to do). But we should get them on Tuesday as well.
Then my partner professionally designs space flight applications - which resulted that a lot of his knowledge went straight into how this light is designed and manufactured. For example this week he ordered space-flight-application grade thermal epoxy (costs a fortune). But the goal was to have the best heat transfer to the rods and exterior (I almost wrote case
). The heat tests we did previously were done without that epoxy - so the heat parameters should improve with that.
Then I got all the batteries. Today I put the first coat of glow paint on them (after carefully wrapping the poles of each one). That glow paint is pretty cool stuff. I was tempted to paint all kinds of things with it... Finally I painted the outside grill of a lamp in the garage that contains a fluerescent bulp - prettty cool how it glows now...... then next were the light switches in the garage... and I would paint countless other things if my wife would let me :devil:.
Ok that much for what happened this week. Have a great week end everyone.
