AndyF
Sandwich Shoppe has these switches I think for $4.
Has anyone tried to take apart the Judco type switch and change out the rubber cover? After many years of service, the rubber on one of my switches is giving out. I prefer these switches to the newer type, so I would rather overhaul this old one with some new rubber than buy new switches.
Sorry for my ignorance, are those the switches on the Mark #1 MD2s?
Thanks,
Peter
As was a subject of much debate on these forums back when these types of switches were the proverbial fecal matter, Judco switches and Kroll switches are not the same. Judco are far more expensive, but also far more reliable.
Judco and Sandwich Shoppe both use part number J-1052. Is this the version used in the earlier MD host?.
Send Gene an email. You can probably get whatever your preference is made to order!
Will dc fix on 6p lens smooth out the rings on my m61 219?....Sacrificing a bit of throw sure seems worth it for a nice smooth beam, right?
It should. The DC-Fix blends the beam for a more uniform shape. It will take some of the Sharpness out of the hotspot- personally, all of my malkoffs have DC-Fix on the lens.
This is the reason I always stuck either with bored out SF bodies or FiveMega aftermarket bodies, I've never had a Z41 TC fail on me and if it does, they are a dime a dozen.
Malkoff should have used C-C bodies or at least Z41 compatible tail...
Use Z41 when failure is not an option.
