Things I've learned the hard way . . .(Part 2)
PhotonWrangler
In a handbasket
If you're planning on microwaving some frozen food that wasn't designed for microwave heating, start out using a low power setting. I put some spinach & cheese raviolis on a paper plate and popped them into the microwave on high power for 2 minutes. One of the raviolis caught fire and burned a portion of the paper plate.
The worst part is the whole place now reeks of burned cheese and paper. :sick2:
PhotonWrangler
In a handbasket
Batteries are sneaky little buggers and will leak when you don't expect them to. I just looked at a AAA battery holder that had one cell in it, and it leaked all over the contacts. The battery wasn't very old either. Luckily it was an easy cleanup and caused no permanent damage.
PhotonWrangler
In a handbasket
Bought a bug zapper. This unit has 2 10w BL (unfiltered) UV tubes in it. I plugged it in for a moment to test it and confirm that the lamps worked. Then I unplugged it and pulled off the back shield to pull one of the tubes out to get a better look, and I got a strong shock. I noticed a quick whiff of burning flesh from my finger.
The shock felt like AC, which means it's internal HV supply was still running off it's power supply capacitor even though it was switched off and unplugged. This product is not intrinsically safe. So I jammed a screwdriver between the electrodes to short out any remaining voltage before removing one of the bulbs for a closer look. In retrospect I should have done this first.
Pacific N.W.
So, you were bugged and zapped by a bug zapper. I know I shouldn't mock your pain, but I find that hilarious. :laughing:
Way back in this thread I posted about being BIGTIME zapped by a capacitor in a television set I was dismantling. Man, that hurt. So, I've felt your pain.
~ Chance
PhotonWrangler
In a handbasket
If you store some cans of pop in a cupboard for awhile, check on them occasionally. We discovered that several cans had spontaneously leaked over time, even though they never got particularly hot or cold. I didn't know that pop (soda) did that.
Monocrom
NYC
Don't us Visine or Clear Eyes on a regular basis because once the drops wear out, the redness comes back even worse. They're fine if you're going out on a night on the town and have redness. But not daily use. Basically, you then have to always use them. Natural tears are better. Your best bets are Refresh or Systane. The latter being better of the two.
Just found that out today from a well-respected retina specialist, today.
PhotonWrangler
In a handbasket
On a related note, I've found that I build up an intolerance to certain eye drop formulas over time. When I try one that feels good in my eyes, I can generally use it for 6-8 months, and after that it causes my eyes to itch.
However I've found one formula that doesn't cause this problem for me - any product where the active ingredient is sodium carboxymethylcelluose. I usually don't remember the full name when I'm shopping for eye drops, so I just remember to look for "carboxy" in the active ingredient section and I know it's ok for me.
PhotonWrangler
In a handbasket
Screen printing is a lot trickier than it looks at first. I've been tinkering with it and I've made a number of rookie mistakes. It took forever to finally get a respectable looking result with simple text. Still hammering out problems with graphic reproduction.
PhotonWrangler
In a handbasket
Alcohol is great for cleaning a lot of things. Cheap reading glasses with plastic lenses, not so much. The alcohol reacted with the lenses and left a distorted mess.
Pacific N.W.
