Swedpat
The run time on high vs turbo seems off.
Going from high to turbo nets more than a 100% increase in brightness, but only a 10% decrease in battery life. Does Turbo step down due to heat?
-Turbo (3800 lumen; 130 minutes)
-High (1800 lumen; 145 minutes)
-Medium (320 lumen; 10.2 hrs)
-Low (38 lumen; 46 hrs)
-Firefly (0.5 lumen; 37 days)
-Strobe (2280 lumen; 180 minutes)
The technical specs are highly misleading because they are according to ANSI-NEMA standard which means the runtime is measured until output is 10% of initial. Likely gathered regulated runtime at high mode of 1800lm I guess is 40-50min and 15-20min at turbomode. Therefore I think the levels are unnecessary high. But I may underrate the efficiency of the XHP 70 2nd gen LED; is it much higher than MT-G2, anyone who knows?
