briteflite
PP sent to reserve one light. Thanks for bringing these to CPF!
Eala: I'll post some beamshots in the next couple of days. By analog driver I mean one that doesn't require multiple on-off cycles in order to switch modes - you're not using a microcontroller to read highs and lows to determine what your output is. If you've owned an Aeon, Nautilus, or Mako, it's the same sort of interface, just with a third level. None of my lights ever leave you in the dark, either, they just fall out of regulation and become dimmer once the battery falls below a certain threshold.
Today is the last day for the reservations here on the CPF. Tomorrow I will be adding the light to the website.
Thanks for your support guys, I look forward to getting these lights in your hands soon.
Enrique
The two-stage mechanism already relies on spring compression to switch between Low and High. With a three-stage design, the middle stage would be activated when the spring is partly-compressed far enough to touch the middle ring, but not the inner ring. The only tricky part with creating a third stage is making sure the rings are an appropriate thickness, to ensure the rotational distance between Low>Medium is the same as the rotational distance between Medium>High. However, even that "tricky part" can be easily figured out using mathematics, because the compression behavior of a cone-shaped spring is very predictable -- the widest coils will always finish compressing first, and the smallest coils will always finish compressing last. Only a a couple prototype boards with slightly different ring-spacing would be necessary to test the usability of the design in real life. Given the attention to detail in Enrique's lights, I'm quite sure he's capable of pulling this off.I totally see what you mean for the two stage and I think I understand what you are saying for the third stage, but the third stage mechanism (if it is a smaller inner ring contact) does not 'seem' as robust. You would be relying on the spring compression (which may be ok). We are just theorizing. Enrique could confirm.
I will ponder some more.
eala
Hello Everyone,
Just a quick update - next Friday I will be sending off the request for the parts to be machined; at that point I will list how many were made in this batch, I'll put the light on the website, and the cost will rise to $425 plus shipping for general purchases there.
I hope to have a couple of beamshots early next week for you all as well.
Thanks folks!
Enrique
Enrique, will we still be able to order the Aeon through this thread at $395 plus shipping once beamshots have been posted?
Enrique
Hello Everyone,
Thanks folks!
Enrique
See post 47 this thread.
Bill
