donn_
* A P60 host with a right-angle head
I'll second this one. Make it articulating up and down, and holding 1x18650. Good clip which can be stationed fore or aft. Control button on top.
With our advances in run time and brightness and batteries and regulation, I think companies should start working on elegant AAAA lights, and jewelry lights, not toys or junk, but actual high quality 25 and 100 dollar items, small, slender, even tiny, and fit for fine dressing.
I'd like an 18650 size body with an XRE led there aren't many lights getting made with an XRE bulb now it seems everyone has gone XML mad,i'd like a smooth reflector with a little depth so the XRE punched out a decent throw all of this in the most compact size possible,also it would be even better if the XRE had a neutral tint.All of this with E size compatible threads & 3 modes & McClicky switch
For all these lights and more, I think a 'quiet' switch would be great. Something as durable, easily-replaceable, and high amperage enduring as a McClicky. On the order of a HDS style switch, but that would be backwards compatible with existing lights.
A high output, compact LED flashlight that could survive an EMP pulse/attack would be swell.
So can I. Fin the back of the head, and the body from the switch to the head. Throw in a massive heatsink with the appropriate driver (H6Flex from TaskLED?), and drive the emitter to 6A.
I'm drooling, just thinking about it.
This is a good idea but with 2x18650 body, it will be easier to carry.A single MT-G2 emitter in a head and reflector big enough to properly focus it, on a 3x32xxx cell tube with a side switch. 3 modes; ultra low, med and high.
Unfortunately, not many CR2 lovers.- Titanium CR2-sized tube (E-compatible threads)
Similar to this but "C" head. Right?An ULTRA minimal aluminum single 18650 p60 host.
