What LED flashlight(s) can be made but nobody makes them?
What would you like to own which is not existed but doable with today's technology?
What body size? Head size? Form factor? Battery chemistry? Battery configuration? Number of cells? Brightness? Run time?
What host would you like to own to use with P60 type modules?
Let's be realistic and concentrate to LED only.
Please check incandescent here
I would love to purchase a straight cylindrical (head diameter same as body diameter) multi-cell multi-emitter light in the SX25L3/SR Mini/TM06 size classification. But with a lot more lumens than what is currently offered. A lot lot more more lumens.
How about something with the same form factor, body diameter and head diameter as the TM06, same four cells, four reflector wells.
50 mm head and body diameter, with four cells and four XHP50 or four XHP35. The light may be longer, to accommodate thicker heat sink and deeper reflector wells.
7,000 lumens would be nice.
Oh, and don't forget lower modes available for those few occasions when I don't want to unleash the power of the cells as quickly and brightly as possible.
I have hope that someone can make such an item. Something to look forward to in life.
