raggie33
*the raggedier*
- Joined
- Aug 11, 2003
- Messages
- 13,593
i want to be able to charge one aa enelope in 5 hours or less.
cool ty i may even have one
if you want a fixed setup you can use a smaller size and charge a USB powerbank, doesn`t matter if it takes days to do, and then use the powerbank to supply your eneloop charger. that`s probably the easiest way using off-the-shelf parts.
Yup. Or, use the solar panel to charge a SLA deep-cycle battery. Then, use a charger that accepts 12v input to charge your small cells like Eneloops. The SLA battery will store up 1000 Wh, enough to charge a couple of hundred Eneloops if there's no sun. Or your laptop, phone, etc.
