therock
- Joined
- Feb 26, 2005
- Messages
- 195
It looks like the height and side adjustments are fixed to each other between the high and lows. It kind of makes sense that if you make a near precision head lamp set for a particular vehicle you will know where the highs should be in relationship to the lows. I found that Zizala is capable of that.
I very carefully did the lines on the wall method as a preliminary setup until a beam setter adjustment can be done.
When I made my low beams cut-off and right angle rise intersections hit their cross hairs from 25' on the line two inches under their center line I then hit my high beams. They were nearly perfectly on their cross hair positions on the top line. Zizala I am impressed! I backed away and they remained steady.
I then gave them the test of having my girlfriend following me while I drove her van and drive towards me in the on coming lane on a back road and they are fine. Then we swapped and I got her opinion to confirm.
In looking at them from her van straight on and in her mirror the light is quality is amazing. Though not offensive you can tell they are not wimpy. You do not even think about color because its white.
I also had her hit the highs on me and man it did not take long for me to say into the phone Ok - OK! If I have to flash anyone it will not be for long. I am glad I had her do that. A flick for a hint is fine but any more will be unsafe for both of us. Those Osram 65w H7's are amazing.
Its a little windy here so its clear out and the roads really light up nice on high.
On my very first runs made without the target line setup had the road signs blinding me. I now know it was because of poor alignment. Thay have tamed down some.
I was so into my setup I forgot to take pics. I will though because I want to see the "After the beam setter" comparison to my line setup. I will post that when I get it done.
- I used a tripod and a level to find my lamp center heights. My garage floor was poured very nicely showing between the lines on an 8" level.
- Then I drew a center line and the horizontal lines on a 10 foot wide sheet of card board with a straight edge at low beam center and at two inches lower.
- Then I marked the vertical centers for both beams and found a spot that was close to level checking with an 8 foot level on clean concrete.
