greenLED said:Heat= temperature for our common purposes, doesn't it?
IMO, it's pure *fad*.
Temperature and Heat are like Volts and Current. If you don't mind confusing those two, then I guess you're in good shape.
You apply a certain amount of voltage potential across a resistor, and you get current. If you apply two temperatures on the sides of a piece of material, you get heat. The thermal resistance is the reciprocal of the thermal conductivity, the metal is acting as a resistor for heat.
The rule here is that the heat flowing is proportional to the product of the thermal conductivity and the temperature differerence across the system.
A LED produces waste heat. This heat needs to go somewhere. If it can't leave fast enough, it builds up on the device as excess temperature. The temperature rises until there is enough temperature difference between the source and the ambient (like voltage and ground) so that same heat (current) that is flowing from the electronics flows through the thermal resistance between the device and the ambient. This is considered the steady state temperature of the system. This temperature needs to be below the limit of the materials of the device.
