I don't think I'm fully neutral on titanium, I've got way to much Ti stuff to say I'm neutral.
But what I noted on my titanium mugs is that they retain their shape, are much stronger than the aluminium I had before and are easier to clean, although I wouldn't recommend baking in them. My Titanium mug has lasted me now for over 8 years, when my aluminium mugs wouldn't last me a season. The alu's got bend in my pack, I even had one melting when I did put it in a coal-fire to heat up the content. The titanium I forgot turned deep dark blue, but certainly didn't melt. So titanium can have it's uses, for sure!
I've made a titanium notebook, with a titanium coil, with teslin-plastic-sheet-paper. Why? because it made a far better notebook than the aluminium I had before. The aluminium got really dirty over time and it bended and dinged way to easy. Ow and it corroded in a marine environment until it had more crystals on it than the jar of salt I left in the shed. So titanium was a better. I had a carbon fibre as well, 2mm thick sheets and they cracked when I didn't use them properly. I didn't abuse them, but on the beach I grabbed the notebook and got up on my feet, supporting myself on the notebook. Underneath was a little pebble and the carbon-fibre cover just cracked. Darn, not a good material for a notebook cover, but an expensive experiment (the carbon was water-jet cut at 4000 bar (??60.000 PSI??) and those machine's aint cheap, that's for sure)
Back on topic to titanium lights. I live in a river delta, on an island, I like to go kayaking, I like to get into the water/sea/surf. I swim across rivers which are 300-400 meters wide, I plough through mud-fields when the tide is out.
All of my surefires did survive this (although the selector ring of the U2 didn't like it) and the SF's where perfectly usefull. But the dirt seems to get into every crack and stain the alu lights. If the light dings, the bare aluminium gets stained as well. And SF lights do get those dings easily if you climb out of the water onto a rocky shore that is slippery as h*ll. But more important to me is that the SF's don't have flood-lighting, and don't have a really low-low that I use for map reading, writing, reading a book. And that is where the titanium light's from Don comes in:
a Sundrop with low levels, flood and it is made from titanium.
Would it have worked, if it where made from aluminium? likely yes. pretty well.
but now I've got a light made from titanium and I love it.
My wife calls it man-jewelry. I think she's right.
Just one last thing, I think the termal properties of titanium are a non-issue.
My HAIII aluminium surefires are just as bad at conducting heat through the HAIII into the still standing air as my titanium light
One of the worst conductors of heat is still standing air. so you need to hold the light to get warmth away.
As a ceramic:
Thermal conductivity 25.08 W/mK at room temperature.
CRC Materials Science and Engineering Handbook, p.281
As a single crystal:
Thermal conductivity 43.05 W/mK at temp=20 C.
CRC Materials Science and Engineering Handbook, p.282
And at higher temperatures it only gets worse:
Thermal conductivity 16.72 .. 28.84 W/mK at temp=100 C.
Thermal conductivity 12.54 .. 26.75 W/mK at temp=200 C.
But now look at air:
Thermal conductivity of Air 0.024 W/mK
That is 1000 times (yes, thousand) worse than titanium.
What can I say, AFAIK, thermal conductivity between HAIII and Ti is a non-issue in testing stands, and when you hold the light, the difference between a layer of HAIII and titanium is likely to be very, very small.
If you happen to have a non-coated aluminium light, the difference is bigger, but I couldn't use, as the salt water would corrode the threads within a day to such a bad shape that I could only throw the light away after the battery is empty.
Pfooeeeiiieee, My post is almost as long as some of Don's posts :nana:
