SneakyCyber
I started with the dash
Dash Before
Dash AFter
It turned out prety sick looking. Took about 2 hours because I solderd two leds backwards and had to figure out which ones were wrong.
Tips Learned: Leds can take alot of heat when there off. Draw a diagram of the polarity of the stock LED's incase you get one backwards. If you do get one backwards depending on where it is in the circuit one or more LED's wont light. Test the panel after a few LED's to make sure your getting good contact with the circuit board. With this particular instrument cluster the new LED's were too bright for the gearshift indicator background lighting so I omited those and changed the selected LED color now they only light depending on what gear your in but there not lit all the time. Use a damp sponge to keep your soldering iron clean. Keep your iron tip tinned before each soldering task. Repeat after me: Wipe, Tin, Solder... Wipe, Tin, Solder. Do this each time and you should have no problems. Have and assortment of small tools to handle the LED's I used a straight pick, A 90deg pick, a pair of tweezers and my favorite tool was a gerber clutch pair of pliers. You may also want to have a magnifying glass handy becuase these LED are TINY!
Will post more pics of the interior as I finish. The AC controlls are changed but need some tweeking of the led placement.
Dash Before
Dash AFter
