This is a nice AA cell to D cell (1.5V) battery adapter.
Thanks go to gregw who pointed this out in the ProMagnum thread as available here .
While these are well made, they also come with problems right out of the box.
The holes in the plastic front spacer plate are too small for the positive battery terminal to fit through. But luck has it that these are easy to disassemble and fix.
First, turn the rear contact plate to unlock the assembly.
Then bend the metal contacts up a little.
Push on the positive contact and shove the rear contacts back through the hole in the end a little.
Now all the parts can be easily removed.
Use a 7/32 drill bit followed by a 15/64 drill bit to ream out the holes by hand.
Reassemble the parts as shown in the photo so the center strut is seated in the plastic front spacer plate.
Then just push on the negative contact to snap everything back in place. Turn the rear metal contact part to lock the adapter parts in place. Now the positive contacts fit through the holes and make contact.
That's it, adapter fixed and ready for AA cells.
This adapter costs $3.25, so for two of them it will set you back $6.50 plus $8.00 shipping from Aventrade. Aventrade did ship my order the next day and I received them a few days later by UPS.
If there is enough interest, a group buy can be made to save on shipping costs. Any interest?
