$5.48 clearance price at Target.....
Packaging and size comparison -
Heads and LED -
Construction -
Side reverse clicky switch, the heads unscrews, and it does give some focussing ability - the screwed down tight position seems the tightest hotspot position - one can get a wider hotspot before the donut hole starts appearing......
To cut to the chase I am VERY, VERY impressed.
I've had a 3D MagLite for quite awhile - wanting to upgrade to LED - but most of the LED drop-ins were "expensive" costing more than the original flashlight
- however my procrastination has allowed me to do a lot of research and reading of CPF'er's opinions - basically it boils down to looking at 3watt Luxeon level - and possibly waiting for the actual MagLite offerings to see if the market evens out to more mainstream/commodity pricing.....
So I thought a 1watt Luxeon 3D was "silly" - who'd want a 1watt level of brightness using 3x D cells?
Boy! was I in for a surprise.... dropping in 3 alkaline D cells and turning the light on - I thought it was bright.
OK, compare it to a 3D MagLite standard Krypton bulb - I thought this Dorcy was brighter - taking them outside (last night) and shining the lights at some distant tree tops - I could clearly make out the spots of both lights at approx (estimated) 100 yards....... WoW!
Since I only had 2 sets of 3D alkalines - I actually put the used batteries in the Dorcy 1w 3D and the fresh ones in the 3D MagLite.......
vs. 3D MagLite fresh batteries
Very comparable - perhaps the side-spill of the Dorcy is brighter (remember this is on used batteries and the Mag is on fresh out of the pack batteries......)
Now it may seems silly to take a comparison beamshot at only approx 8" - but this shows the entire beam and vital side-spill -
OK, so it is still "silly" - so backing the lights to approx ~4ft/1.2metres away
Now one can see that the hotspots are very comparable - this is indeed very impressive considering how tight one can focus the 3D MagLite and and its reputation for throw....
At this stage I'm beginning to realize that this light is more comparable to 3watt Luxeon level......
In fact brighter than 3watt Luxeon on standard primary CR123A -
It took 3watt on 3.6/3.7V rechargeable Li-Ion RCR123 to come close to this Dorcy 1watt 3D -
vs. Nuwai Q3 on 3.6V Li-Ion RCR123
More than just comparable - it seems that the 1watt Dorcy is Brighter!
Here's more proof.......a 4ft/1.2m beamshot comparing the hotspots.
Now this is starting to be, er-hum, controversial........
vs. LightHound V3 3watt on 3.6V rechargeable Li-Ion RCR123 - which was spectacularly bright.......
This 1watt Dorcy again seems brighter(!)
as this 4ft/1.2m beamshot of the hotspots shows......
Now I want opinions/suggestions from CPF'ers -
Is this Dorcy 1watt 3D typical? Have I got an anomoly?
I know all the flashlights I've used for comparison are very much the expected light/brightness/porformance levels -
this Dorcy 1wtt 3D would seem to be stunningly bright with tremendous throw -
so, what is going on? :huh2:
Heads and LED -
Construction -
