I stopped into target tonight to see the new flashlight isle. So exciting. Anyway, i wanted to get the cr123 dorcy 1w, the new single A River Rock light, and there was a new river rock keychain, that looked like the larger styles (spotlight beams) but instead, i diddnt have that much money so i purchased a Brinkmann Go-LED 2 pack for about 2 dollars. So seeing as they are "disposable" i had to rip one apart. The led look very similar to a lambda smjled. I bent the legs out streight, cut them and put them in a mini mag with a stock reflector that was drilled out a little to fit the led. I just did beam shots, no clue on run time. Its not as bright as niteize or sjmled but its still brighter then a led from a lighthound cheapie key chain light. well, for 2 dollars for 2, i dont think anyone will complain. Im going to get more of these next time, and they arent even on clearence. they are new stock, so its a quick easy mod. Check it out
-bobby
If you cant read my writing, the GO LED is on the left, then lambda, then nite ize, then the warm sunny yellow of a good old mag. The batteries were pretty fresh in all of them
-bobby
