Billson
I was playing around with a UWOJ I got from Photonfanatic wondering what I can do with it when it suddenly occurred to me to see if I could take apart my U60GT to swap out the led.
In retrospect, I don't know why it never occured to me to take pictures but it's easy enough to understand the steps required even without pictures.
I first unscrewed the lens and took out the reflector to look at the insides of the light. I saw that the led module unscrews from the rear so I took out the battery and used snap ring pliers to try and unscrew the module. Surprisingly, it moved easily. Seems HDS doesn't use loctite like Arc did or at least mine didn't. The module is a one-piece sealed round cylinder with the led seated in a machined slot where it fits snugly and centers itself. I just desoldered both wires and the led popped off quite easily. Only thermal paste was used so I guess the design uses the reflector to press the led onto the module for proper thermal contact. I just had to drop in the UWOJ led and soldered both leads.
Putting the light back together was just as easy. Just screw the module back into the light. Put in the reflector, lens and screw in the retaining ring.
I'm still kicking myself for not thinking of taking a lux reading before attempting the mod to compare the readings before and after. I guess I never thought it would be this easy. I also saw no point in taking a picture of the beamshot since I have nothing to compare it to. Using my eyes to gauge the difference, I'm pretty sure it's brighter and definitely whiter. Even at the lower levels it seems brighter with barely noticeable hint of tint.
With this result, I'm guessing my light originally had a TWOJ led in it because I got almost the same runtime. I actually got a few minutes more with the UWOJ so this led probably had a lower vf than the one I swapped out. I think I'll to do a burn-in to see if the vf drops some more. Since the EDC is rated based on lumens, I've always assumed the EDC is calibrated by setting the required current until the rated lumens is achieved. If the led is swapped out with a lower vf bin, it should run longer. Can anyone confirm this? If this is so, I wonder what will happen if I buy a 42xr and swap in a UxxJ? Hmm.:thinking:
