I have a P1D ce rated at as 135 lumens boost
Will I go wow with 200 lumens ?
Smarter people than I have talked about eyes and the ability to see.
but .... in a practical world ... is 200 lumens that much better than 135 ?
S
depends. most people can notice a 50% increase in brightness, but it's NOT an overwhelming difference to many.
here's my opinion, YMMV.
if you are using the light to illuminate close at hand and moderately distanced objects, then 135 may be as good as 200, depending upon how much fine detail you are trying to recognize.
if you are observing something more distant, more light output is helpful.
all of this is subject to the reflectivity of the objects being viewed of course. some objects, due to color and surface texture seem to absorb light.
for most purposes indoors, 135 is much more than sufficient (you'd need to be in a pretty HUGE indoor space to even need 135, IMO).
also, please keep in mind that what one Mfr. calls 135 lumen output another Mfr. may call 200 lumen output - some think of this as creative marketing with reality/truth being lesser important qualities.
lastly, beam quality is also very important, and i'm not just talkin' spot vs. flood here, though spot vs. flood definitely enters into play, depending upon what, and at what distance, you are intending to illuminate, but i'm also talkin' about rings, donuts, artifacts, interference patterns, etc.
you might get better responses from more knowledgeable, experienced/expert Posters, if you described in more detail your intended uses for your light, as well as which possible lights you are considering to upgrade to from your P1D-CE - i.e. are you considering a different Mfr., or just a Fenix w/Rebel light?
