Long John
Continued from this light.....:
https://www.candlepowerforums.com/threads/158070
.....I created an "Superduperthrow"-Adaptor
I took a garden flare....:
......and cutted the front and backside to fit the light and a reading-glass with the diameter of 9cm. Important was the right lenght for optimum focus.
After I made a distance-circle from 1mm AL-plate, I glued the reading-glass to it, using a hot-glue-pistol.
Then both to the front of the hopper by 2 part-epoxy. At the side for the light head, I used a piece of a rubber suspension-fork covering for perfect fitting.
Due to this connection, the adaptor is easy to mount and remove dependend on the tasks.
Here a picture of all:
And here the light on "low":
The spot-beam is incredible.
Beamshots will follow later
I hope you had fun
Best regards
_____
Tom
I hope you had fun
Best regards
_____
Tom
