New Lumens Factory M6 Lamp!!!!!!!
senna94
Houston, Texas
I just thought this news was to good to be buried inside another thread. Kudos to Mark and LF!!!!!!!!!!!!!!!!!!!!!
#11
Today, 07:10 AM
Mark@LF
Re: M4 with 3 x 18650's???
Hi, everybody,
Your calls have been answered again.
We have designed brand new HO-M6R for M6 that is using 2 x 3 RCR123A 3.7V recharageable batteries. This lamp assembly can be used in M4 with 3 x 17500's or 3 x 17670's with extender also. The lamp specification is as follows:
13V
Designed voltage: 10.8V
Current: 2.1A
Brightness: 700 bulb lumens
Color temperature: 3350 K
Average Life: 30 Hours. (yes, it is 30 Hours.)
This lamp is not the same as EO-13, and is a brand new design with different filament.
Mark
Paul_in_Maryland
Maryland, USA
2.1 amps? That takes it to 3C, beyond the reach of protected cells. I sure wouldn't want to hold six unprotected cells running at 3C.
Mark@LF
Hong Kong
Paul,
We tested the lamp with protected cells and it is designed for protected cells.
We do not recommend our customers to use unprotected cells as it is very dangerous.
Mark
Owen
AL
Divide it by 2. 1.05A per set of cells. 1.5C for 700mAh cells.
btw guys, I know they're unprotected, but Lighthound has MP R123s on sale for $1.99/ea.
Manzerick
Boston, Massachusetts
Hey Mark,
Would 3 x 18650's work with this bulb? The host would be an M4.
thank you,
Paul,
Mark
SunStar
Paul,
Mark
Hi Mark -
real interested in this lamp and left a question or two in the original post....
mainly wondering if the actual output of this lamp has been compared directly to the MN20 and MN21?? Is it somewhere in between - maybe similar to the MN61 or pretty close to actual MN21 output? Also any estimates on run time from (6) 3.7V protected Li ions?
Thanks for developing this option for us!
LED61
Central America
Even if they are AW's or any other protected R123's, keep your cells balanced guys. AW has charged the cells in the MB20 with the Triton, but still, once in a while, it is a good idea to check the ending voltage after charge on each of the cells, and before charge as well. They should all be pretty close.
jumpstat
Ampang, Malaysia
Always wanted an M6, and Mark@LF has given the perfect excuse of getting one. Got to get a few more Ultrafire-139 chargers also...he..he..
Mark@LF
Hong Kong
Manzerick,
Yes, you can use 3 x 18650's in a M4 with extender.
Sunstar,
The approximate runtime using different rechargeable batteries would be as follows:
M4: 3 x 17500's about 25 mins.
M4: 3 x 17670's about 35 mins.
M4: 3 x 18650's about 50 mins.
M6: (2 x 3) 6 RCR123A about 35 mins. (AW protected 3.7V 750mAh RCR123A)
The brightness should be about MN61, but the MN61 is 2.85A on 4 x CR123A for about 20 mins, it is not as bright as MN21 which is 4.9A on 2 sets of 3 x CR123A. The lamp is designed for the usage of 3 x 3.7V rechargeable batteries (17500 at least, but 17670 better) for M4, and 2 sets of 3 x 3.7V RCR123A rechargeable batteries for M6.
Mark
mdocod
COLORado spRINGs
Mark, I'm really excited to see that you went ahead and did it!!! Great job! I'll add it to the charts as soon as possible....
I'm not aware of a definitive way of getting 3 17500s into an M4... but with a 1 cell extender it might be doable, maybe with a spacer or spring stretch.... unless someone is making 1/2 cell extenders I am not aware of?
The 3x17670 will work with 2x 1 cell extenders on an M4, or 3x 1 cell extenders on an M3T.
To use 18mm cells, boring the M3t or M4 (and extenders) or buying leefbodies will be necessary.
IMO, the best places for these lamps will be in M6s with 6xRCR123s and 3x18650 leefbodies with M heads.
For those who just want the all important answer "how bright." I'll try to break it down to the best of my ability... use these numbers to compare within this comparison only. So if you own one of these flashlights, you can assign this "value" to what you have, to get a better idea of what you get when you switch to a lithium-ion setup with a LF lamp...
An M6 with HOLA on lithium primary cells, Will ramp from around 650 torch lumens down to around 550 torch lumens, in about 15-25 minutes. (depending on cell quality)
An M6 with LOLA on lithium primary cells, will ramp from around 350 torch lumens, down to around 275 torch lumens, in about 50-70 minutes. (depending on cell quality)
An M4 with HOLA on lithium primary cells, will ramp from around 425 torch lumens, down to around 350 torch lumens, in about 15-25 minutes. (depending on cell quality)
An M4 with LOLA on lithium primary cells, will ramp from around 275 torch lumens, down to around 225 torch lumens, in about 40-60 minutes (depending on cell quality)
Now... for comparison with the above statements, I Figure the following.
An M6 loaded with RCR123s and a HO-M6R, will ramp from around 500 torch lumens down to around 300 lumens before you should recharge. Runtime will be anywhere from 25 minutes to 35 minutes depending on the cell quality.
An "M4" style setup with 3x17500s, 3x18500, 3x17670, or 3x18650, will all have a pretty similar ballpark behavior as far as beginning and ending brightness with an HO-M6R. the difference is actually more noteworthy from brand to brand than from size to size... Pila cells seem to really hold the highest voltage under a load, and will deliver the best performance.. larger sizes will of course deliver more runtime, with 17500s delivering about 30 minutes, and 18650s delivering about 60 minutes. Brightness will ramp from around 550 torch lumens down to around 350 torch lumens over the course of the run.
In conclusion, the HO-M6R is positioned very appropriately. I can say with confidence that the 2.1A draw is IDEAL for maximum power while maintaining safe operation in an M6 loaded with RCR123s. It's a perfect balance point. Most cells on the market right now are delivering about 500-550mAH at ~1A (will be 1.05A per cell in this configuration)... so we're right at ~2C on this lamp, which is safe for continuous operation. This was really an ideal and respectable design decision. Mark, you ROCK!
DaFABRICATA
Michigan
Can the HO-M3T 380 Lumen bulb work fine in the M6?
Will I just get improved runtime?
Is it safe, or will it shorten the bulb life?
Mark@LF
Hong Kong
DaFABRICATA,
Yes, you can use the HO-M3T in M6 using 6 x CR123A.
It is safe, the runtime would be about 80 minutes.
But please note that you cannot use rechargeable batteries RCR123A in M6 if you use HO-M3T as the HO-M3T is designed for 3 x CR123A (M3T) or 2 sets of 3 x CR123A (M6) or 2 x 3.7V 17500 rechargeable batteries (M3T).
Mark
BSBG
USA
DaFABRICATA,
Mark
I picked up an HO-M#T from Lighthound last week. It works fine in the M6 - brightness seems to be between an MN15 X-LOLA and the MN20, with a nice round hotspot, quite white.
Only 80 minutes runtime? That's a little shorter than I was hoping for, but still good.
gromit
I cannot find the HO-M6R lamp on Lighthound or Lumens factory site. Do you have a link? Or is it under a different SKU number?
DaFABRICATA
Michigan
DaFABRICATA,
It is safe, the runtime would be about 80 minutes.(M3T).
Mark
Thank you! I now can use my poor-mans M6!:D:D
