Re: What to do with a mag 6D?
While incandescent route would be brighter, battery life would be relatively short. If you want the brightest possible light though; it's the route to go hands down. Now, if you want a bright light with long runtime compared with the above; the single LED route is the way to go. The mod I'm thinking about is just a simple single SSC mounted on the top of a heatsink powered by a driver. Powered by 6D cells, I'm willing to bet you'll get around 10 hours of good, bright light.All in all, it's going to be in the $50 range for everything. You'll also need other things like wire, a soldering gun, flux depending on what kind of solder you use, solder, thermal paste, and other tools and bits. The main parts for this project are going to be a heatsink, emitter and driver to power the emitter. H22A sells the DHS heatsinks with a minimum order of $18 for two (shipping is included). Litemania also sells heatsinks for D cell maglites $17 (after shipping) with out a minimum order. Emitters can be purchased on most large electronic supplies and from fellow CPF members. Just look around for them and know what you're looking for. Don't be afraid to ask the sellers about their product. The driver that I'd buy is the nFlex from taskled. Besides being able to drive the SSC emitter at 1 amp, you'll also have multiple output levels with it. Not only that, but taskled as an australian distrobutor.
