My MTE 5-Mode CR123A Rebel 0100 Flashlight came in this morning ; So no time to wasted . Here is an mini review:
The good
At the price level of $18 this MTE has a decent quality. The threads are clean, The finish is pretty good, there are some minor faults in the adonizing/paint. The clickie works good (not to hard to press). pretty bright. It is comparable/clone (a bit rougher though) to the Fenix P2D but much cheaper and it is one of the earliest flashlights witch contains the new (100 lumens/350mAh) Lumileds Rebel.
It has a nice warm tint (it makes my Crees look blue)
remarks
To bad the reflector is not specially made for the Rebel you can see the rough edge and I prefer an orange peel more than the smooth reflector on this one.(less artifacts) The low is not low enough; about 30 percent of the highest brightness. the hotspot could be tighter for more throw.
You can take the batterycap of in one big turn; a bit strange but it feels solid enough.
When you switch It takes 1/3 of a second for next mode to kick in .
The MTE pulls from the battery 1000 mAh sharp on high and 200 mAh on low ( Dexlight X1 pulls 1550 mAh on high/100 percent and 100 mAh on low)
To my eye this MTE Rebel on high is brighter than my Dexlight X1 on normal high (70 percent/1250 mAh) and it is more efficient
MTE Rebel 0100 next to the Dexlight X1
MTE Rebel 0100 next to the Fenix LOD-CE and the Dexlight X1
All on the highest mode and running on a Li-ion -2 stop autom.
All on the lowest mode and running on a Li-ion -2 stop autom.
In total: I think It is pretty good although not a collectible.
edit:
on a unprotected Li-ion 800mAh (real life 600mAh) I get:
After 25 minutes about the same brightness and a slight increase in current draw (1050 mAh)
After 30 minutes now it begins to dim (600mAh)
After 40 minutes it is dim (150mAh) (battery is down to 3,34v at this point)
more remarks:
-I have to remind myself not to be to hard:this is a $18 flashlight not a Fenix 3x the price
-No traces of PWM
-hard to tell if in mode high, mid or low
-remembers last setting
-glass lens
-plastic reflector
-nicely centered led
-can't unscrew the head
-seems waterproof
edit2
I just opened the flashlight (difficult because of glue)
No grease between the rebelstar and the heatsink. (both very flat so no disaster)
But is has a nice AMC7135 driverboard in it (3x so about 1000mah)
Also it is easy/better to reverse the midsection so you have more thread on the tailcap
O-rings between all the different parts
The good
remarks
edit:
more remarks:
-No traces of PWM
-glass lens
-plastic reflector
-seems waterproof
edit2
