Northern Lights
Building a tri-build LED light can cost more than buying one from a good vender:
http://www.qualitychinagoods.com/powerreg-cree-high-power-flashlight-p-782.html
As a matter of fact this light is probably brighter than most modified lights and the one piece reflctor appears to be the same as the Shyguang Nuwai TM-800x3 and it has different modes too. So why build a tri-build light?
I think the best excuse to build the light is run time. Second excuse the reflector supplied with the TM-800x3 is one piece a proven thrower that because of its one piece manufactured design is alway collimated! Only a good size power pack will give you the long run, like a 3D size.
The best and easiest LED tri-build host light is the TM-800x3, well, maybe.
(used with permission from ED!)
The Nuwai TM-800x3 has been around, a sleeper it was and is a great light as it comes with LUXIII luxeons of various tint bins. CPF folks found that an easy mod was to change from 3D cells to 4 NiMh C cells and boost the votage to 4.8Vbat and then you pretty much got the lumens that Nuwai claimed, 200+ with all three LEDs illuminated. But that has led up to failure on some LEDs because it was too much Vf for the bin. I burned out two this way. This light is made in 4D and 3D by Shyguang and Nuwai brought the 3D to the USA:
http://www.shykuang.com.tw/new%20english_web/p06-03-TM-800X3.html
http://www.shykuang.com.tw/new%20english_web/p06-07-TM-802X3.html
(I always have trouble loading these site)
Ed, LED_experimenter, sells them, http://www.cpfmarketplace.com/mp/showthread.php?t=111651&highlight=tm-800x3 . The same reflector appears to be used in some DX and qualitychinagoods lights now, the 3-cree MX light for one. That reflector is one piece so it is perfeclty aimed and collimated for throw.
The circuit is three parallel resistor drive circuits, that is the LEDs are not in parallel or series, each has its own circuit and the light functions turning on 1-2 or 3 of the circuits. This assures balanced power to the LED so if you do not over voltage it, it should run forever. The circuit appears to have a power equalizing circuit before each of the LED circuits take off. The board is behind the generous heat sink. Very ingenious design, well done.
Now for the best build! I put in three U bin SSC P4s. Fred, photonfanatic, has the P4, http://www.cpfmarketplace.com/mp/showthread.php?t=169467. The P4 angle of the emitter is close to the Luxeon and not as narrow as the Cree so it works well with the reflector. The P4 is 3.25 Vforward so I could use 3D batteries for a very long burn time, Vbat=3.6. Recently I saw a comment from 3rd Shift that he likes to power a light this way too, http://candlepowerforums.com/vb/showpost.php?p=2159914&postcount=29. Some Ds are 10-12 Ah capacity and if you are running 3 amps on high figure 3+ hours run time on high.
I ran my P4s at just under 1amp for about 240 lumens each! In comparison my mod light is brighter with one P4 running than a stock light with 3 LUXIII running! To mod the light I replaced the resistor with two resitors in series to get .36 ohms for each of the three circuits. I was not able to find a .35 ohm 2 watt resistor locally, that would put it at 1 amp; I should be running at .972 amps, (972mA), just a little safer margin against burn out I would say. The stars just drop in, exchanged them with the Luxeons.
I had a problem where the reflector wanted to spin when putting the bezel on, I sheared off one set of P4s that way. I solved that by putting a pin through the top edge of the bell into the reflector and then put the bezel on. I drilled a hole in the edge through the aluminum and plastic and modified a brad picture nail to be short with a flat small head. BTW- a TM-800x3, 3 resistors and 3 P4s costs less than a mag mod thri-build and consider I only changed three LEDs and 3 resistors.
My favorite tri-build:
I have up to 720 lumens at over 3.5 hours time, well, maybe.
Coming soon are some Q5s, a driver and 3x AW lithium C-cells for my next TM-800x3 modification.
Need some help here, I lost the links to the CPF thread where a photo spread is done on the dissasembly of the TM-800x3 head, PCboard and switch. Can you find it? Good shots to reference to from this thread.
Above I mentioned two vendors of production lights. I think I should mention that Wayne at Elektrolumens makes some great tri-build custom lights to consider too.
