You'll lose 5% in 24 hours......
Pila IBC charger, IMO.45/70
What do you consider to be the best charger-battery combo for this type of battery ?
Thanks, again Bruce
45/70
There is a commonly believed myth that Li-Ion cells have a "rested" voltage that is lower than "Hot off the charger". This is not precisely true. The only reason a Li-Ion cell will have a lower voltage, say, 1 hour after it comes off the charger, is cell degradation....
Dave
There is also a common misconception that the "no voltage loss" rule associated with Lithium Cobalt chemistry cells carries over to other chemistries... LiFePO4 and LiMnO2 chemistry cells will loose some voltage after resting from the charger even when brand new.
Eric
Just speaking for me, but I have never had a Li-Ion drop to 4.1 volts after being charged to 4.2 volts, within 24 hours. I am talking about 30 or so Li-Ions over a three year period. I have one UltraFire 17670 that will drop to 4.14 volts within 24 hours or so, and that has been the case since I purchased it. I will not run that Li-Ion in series.
Bill
