18650 Battery pack...Will I blow up ?
H20doctor
seattle
I want to run 8 of these in series 29.6 volts
in this custom made battery pack
to run a flashlight.... the ultrafire 18650 have an internal PCB inside the battery
1) I am only discharging the batteries to run the light
2) once drained the batteries will be recharged in a Li ion smart charger.... 2 at a time
I need to know if this is possible ....?
Thank goodness I won't Blow up cause the batteries and the charger cost me 80.00 .. Thank you candle power forum for the expert advise
another "+1, there is no danger at all"
but consider the initial voltage will be around 33.5 V
and that the circuits might not allow a high current draw (something about 2 A should be possible)
