things
Hi, i've just received my flashlight from dealextreme, and I also forgot to order some 18650's with it. Now, I've recently pulled apart a laptop battery that has lost it's capacity, and it turns out it has like 12 18650's in it :D
So i've extracted 2 of them, and they work in the light fine, and I also bought a ultrafire charger to charge em with. Would these batteries be fine in the flashlight, even though they are pretty dead? well, they may not even be dead, but I have had them on charge for about 2 hours now and they are barely even warm, which is good to know (Though I do check them every so often)
Should I be worried about fires/explosions more with these batteries, then, if I bought some new ones?
The flashlight is extremely bright (rated 900 lumens), which indicates the batteries are working fine (Although havent done any longetivity tests yet)
Is there any more dangers to using used batteries than new ones?
Cheers,
Dan :)
Cheers,
Dan :)
