mtbkndad
- Joined
- Jan 1, 2005
- Messages
- 1,295
Hi Everybody,
Here are my photos. There are quite a few and I did not want to do contact sheets so that the images would be larger and more useful for examination.
I have limited them to 640 pixels wide so that should help some with download time.
The target was the lowest horizontal cross bar of the tower 250 yards away. It was very challenging to get the beams centered on that bar from this distance. One problem is that HID hotspots are not always centered in the corona and this will change the appearance of the beam pattern slightly on the ground. I did my best to get a balance with the lights since I was doing the aiming of everything.
I have ordered the lights in terms of how well I felt they lit up their tiny ( the cross bar) target, regardless of how much overall lumens they put out, from lowest to highest.
I do not have all of the low powered mods in this post. It is already quite long in it's current form.
Also, as is my custom, I did the shots from behind the lights so you can get a good idea of the total light output and beam pattern that each light produces.
My Canon S2 IS was set to f3.5, 3.2" . I leave the ISO standard and the color balance automatic. This is because I feel gives a truer picture of what I am actually seeing then if I use a daylight setting. The lights that look blueish or greenish really do look like that in comparison with the lights that don't have the same appearance. This is particularly true of the lower powered lights that are really being used on a target either beyond their useable distance or at the fringe of their useable distance.
Control
Enzite 10 watt
Mac Mini HID
28 Watt Black Widow
Superlight 28 Watt
Microfire K3500
Beast 1
Volcano Mod
HB1 50 watt
Yellow Jacket at 35 watts
N30
Secret 35 watt HID- Not available in US, but uses the same reflector and bulb as the up coming L35.
Polarion P1 35 watt
X990
Polarion X1 (Mr. Ted Bear's)
Polarion PH 40
Sam's POB
Polarion X1(mtbkndad's)
XeRay 50
Polarion PH 50
HB 2 New Bulb- At dinner I mentioned to Phil about HID's getting brighter as the break in. He just built this one the day of the shoot.
15 MCP Thor
AI/Titanium Illuminator
Yellow Jacket at 65 watts
HB 2- Bulb with some burn in time
Costco HID- The Costco HID and Mega Illuminator are very close and could go either way. I put them in this order because the Mega Illuminator was clearly aimed a bit high.
Titanium Mega Illuminator
BarnBurner 75 watt
BarnBurner 80 watt
Larry K. 600 watt
Larry K. 1000 watt
Costco 80 watt mod
HyperBlitz
300 watt Blackhawk Locator Light
Now for the Cropped shots.
Enzite 10 watt
Mac Mini HID
28 Watt Black Widow
SuperLight 28 watt
Microfire K3500
Beast 1
Volcano Mod
HB 1
N30
Secret 35 watt
Polarion P1 35 watt
X990
Polarion PH 40
Sam's POB
XeRay 50
Polarion PH 50
HB 2 new bulb
15 MCP Thor
HB 2 50 watt bulb with some break in time
Costco 35 watt HID
BarnBurner 75 watt
BarnBurner 80 watt
Larry K. 600 watt
Larry K. 1000 watt
Costco 80 watt Mod
HyperBlitz
300 watt Blackhawk Locator light
Take Care,
mtbkndad :wave:
Control
Enzite 10 watt
Mac Mini HID
28 Watt Black Widow
Superlight 28 Watt
Microfire K3500
Beast 1
Volcano Mod
HB1 50 watt
N30
Polarion P1 35 watt
X990
Polarion PH 40
Sam's POB
XeRay 50
Polarion PH 50
15 MCP Thor
BarnBurner 75 watt
BarnBurner 80 watt
Larry K. 600 watt
Larry K. 1000 watt
Costco 80 watt mod
HyperBlitz
Enzite 10 watt
Mac Mini HID
28 Watt Black Widow
SuperLight 28 watt
Microfire K3500
Beast 1
Volcano Mod
HB 1
N30
Secret 35 watt
Polarion P1 35 watt
X990
Polarion PH 40
Sam's POB
XeRay 50
Polarion PH 50
HB 2 new bulb
15 MCP Thor
Costco 35 watt HID
BarnBurner 75 watt
BarnBurner 80 watt
Larry K. 600 watt
Larry K. 1000 watt
Costco 80 watt Mod
HyperBlitz
Take Care,
mtbkndad :wave:
