Thank you CKOD! After trying multiple options, some SST-50 specific, some not, the Carclo 10391s were exactly what I was looking for. They turned this massive 5000+ lumen flood light into somewhat of a thrower. Here's a few pics to update the progress:
Carclo's sitting directly on the dies...
The entire gang of misfits...
Jetbeam RRT3-XML at 1950 lumens for ceiling beamshot comparison...
Ledil spot reflector for SST-50. Jetbeam on right, Quin SST-50 left.
Olight 20mm reflectors bored to fit SST-50 dome.
And finally...success with the Carclo's. Killer hotspot, can't wait to get these mounted up and get outside.
I'm not real proficient with the camera on anything other than auto. The beamshots don't do the first two pictures justice as to the floody nature of what's on my ceiling. I think the hot spot of the Jetbeam becomes the focus making the floodiness of the Quin-50 much less visible. The Carclo beamshot does capture what I'm seeing accurately...two great hot spots, one much larger than the other.
I've still got alot of work to do on heat management. I ran this at 5A for about 10 minutes while swapping reflectors, taking pictures, etc. The head reached 73 C, lots of room for improvement there.
This leads me to a question for the pros on this forum... With a variable power supply, I am essentially running these direct drive/constant current/constant amperage, no PWM/no duty cycles. Does the H6Flex use PWM or a frequency/duty cycle that will relieve some of this burden and possibly lower my operating temperature?
Thanks again for all the input...especially CKOD...those Carclos are awesome!
